It is currently 17. May 2024. 18:09
Reply to topic  [ 2444 posts ]  Go to page Previous  1 ... 236, 237, 238, 239, 240, 241, 242 ... 245  Next
TEMA ZA ČAVRLJANJE
Post Re: TEMA ZA ČAVRLJANJE
Pisača mašina :LEGO07: Nisam ni "ubrao" ovo kao ideas.. ali final product mi odlično izgleda.. Prilika klincima vidjeti to čudo tehnike prvi put u životu :LEGO07:
https://www.youtube.com/watch?v=LeLA7gZzdtU
09. Jun 2021. 18:30
prekrasne stvari, ali opet mi je zao dati lovu da mi samo stoji kao ukras ;)
09. Jun 2021. 23:29
Nisi doživio u videu da je dobar parts pack? :LEGO39:
10. Jun 2021. 08:28
U zadnje vrijeme ima toliko Wow setova da ovaj nekako nije interesantan, da je izašao prije 10 ili čak 5 godina bio bi hit.
11. Jun 2021. 08:47
Kao npr. ova? :LEGO22:
https://www.flickr.com/photos/legols/25073225485/
http://www.brickset.com/search/?ownedby=dudek
11. Jun 2021. 12:40
Kako obnoviti naljepnice koje prljave.
Successfully restored some old and heavily peeled transparent stickers by using a simple sticker maker.
Used items:
- Plastic razor scrapper* (make sure it has plastic blades to avoid damaging parts and/or stickers)
- Xyron X150 sticker maker (with permanent glue cartridge)
- Tweezers
- Adhesive remover fluid*
- Paper towels
- Optional: hairdryer
Steps I used:
1. Carefully remove the sticker from the bricks using the plastic razor scrapper. Make sure to avoid any stress which can cause damage to the sticker! Optionally you can use a hairdryer to heat up the glue a bit (medium setting) for easier removal.
2. Clean the back of the sticker with adhesive remover and paper towels to remove any glue and/or dirt. Be careful not the leak any fluid on the front of the sticker! This may cause damage to the print.
3. Clean the brick from leftover adhesive with the remover fluid, or replace the brick when it's discolored and/or damaged.
4. Wash the sticker & brick with regular water. Rub the sticker a bit to remove any dirt on the front of the sticker as well. Let them dry out for a while or dry them with paper towels. Try to avoid collecting dust and/or new dirt on the sticker & brick during/after this step.
5. Use the Xyron sticker maker to apply a new glue coating on the back of the sticker as instructed. Detailed instructions about using the sticker maker can be found on YouTube as well.
6. Use your tweezers to carefully pick up the sticker to re-apply it again. Since the new glue coating is really sensitive to vinger prints, I definitely recommend using tweezers here.
7. Carefully place the sticker on your parts again and rub out any air bubbles. The new glue is a bit less forgiving, so make sure you apply it correctly at once (otherwise back to step 2).
8. You can optionally use a hairdryer (medium setting) to heat up the glue a bit while rubbing it down. In my opinion this was definitely beneficial to the end result and distributed the glue more evenly.
09. Jul 2021. 16:08
Hvala! Probat ću! :LEGO04:
Pratite Klub Kockice na Facebooku i Instagramu! :D
09. Jul 2021. 16:56
https://www.logicno.com/politika/twitte ... dnika.html
Eto Lego bude završio na sudu , da ruši USA ;)
10. Jul 2021. 12:29
Mislio sam da je to neki sarkasticni post. Nije im problem sto su mu nasli oruzje vec lego set Capitola.
10. Jul 2021. 15:09
Romanos je spomenuo da ljudi na izložbama često pitaju koliko kockica je trebalo da se nešto napravi.
Postoji li neki broj s kojim bi se mogla pomnožiti težina kreacije pa da se barem otprilike dobije broj kockica koji je potreban za kreiranje ??
DODATAK
Uzeo sam da je prosječna kockica 1x2 brick (oznaka 3004) i onda ispadne da je 1KG oko 1200 kockica. Ali zbog jednostavnosti i toga da na webu kažu da je po 1KG oko 700 ~ 800 kockica možemo uzeti da je u grubo 1KG = 1000 kockica.
03. Aug 2021. 19:26
Users browsing this forum: No registered users and 15 guests
